xj88superjeep
- NJ
Does anyone know if the positive lead for switching on the fan with the air on is the same wire that switches it on for the defrost? I am gonna be wiring up an adjustable e-fan control, and it says to jump into the same positive as the air conditioner, but I still want it to run when I use the defrost too. So is there a wiring guru that can help me sort it out before I start so I am not stuck with trial n error... I got the Hayden 3651 with the threaded temp switch that plugs right in where the factory switch is, but has it's own relay with an adjustable tstat/fan control. It does not help that they included the instructions for a DIFFERENT model, and I cant find a writeup on it. Should I relocate the location of the temp switch to somewhere else like the lower rad hose? I appreciate that most of you probably just use a toggle switch, but if there is anyone who has rewired the factory wiring to an aftermarket unit, could you share your wisdom?
THANKS! :worship:
THANKS! :worship:
