That set up on projectxj.com looks pretty getto for a perment set up. If you want to do it right so you don't have any problems with it. Use quality connectors, and a heavy duty relay. You need a relay rated for 40A at least, a heavy duty water proof fuse holder and 10AWG wiring for the high current side of the relay. As far as the switch, and the wiring into the cabin it's not to important as to the guage of the wire as long as you fuse it correctly.
Here are some links to
Del City A good sorce for automotive wiring hard parts.
Heavy duty water resistant fuse holder.
It's only rated for 30A, but I,ve been using one for a while now without any problems.
Heavy duty SPDT 40/50A relay with socket.
I have found it's better to run a relay socket in the engine bay where it's a harsh enviroment.
Good crimpable terminals.
If you use these you're going to need a good crimper. Not one of those cheep auto parts store things. Get one like this.
Ratching crimper. I have the bottom one. As far as the terminals go you'll need 12/10AWG (yellow) butt connectors, 12/10AWG ring termanal 8 stud IIRC, 16/14AWG push on terminals. Other wise solder every thing, and use heat shrink tubing to seal the jont. You're also going to need 10AWG wire, and I normally use 14AWG, or 20AWG for all my switch wiring, and usually just buy that from Auto Zone.
Starting at the PDC's main battery post (under the little cover). Use a ring terminal to connect the fuse holder. Butt splice the 10AWG wire to the other end of the fuse holder, and run it around to a location near the factory plug for the fan.
Now what you want to do is cut the power wire to the fan (I would cut before the plug so if you ever have to replace your fan you won't have to disasemble your wiring). Run the Factory power wire to terminal 87a on the SPDT relay. The new 10AWG wire will go to the 87 termanal, and the fan side of the power wire will go to termanal 30. (This will allow the NC (normaly closed) contacts in the relay to pass current to the fan for factory operation.) Connect termanal 86 to a ground, and 85 will go to your switch inside. A good place to get power from inside is either the cigerett lighter (switched), or the power port (not switched). As long as you use 14AWG wire for your switch wire to the relay the 20A fuses already protecting those circuits will be safe, but if you use a smaller size wire I would add an inline fuse to protect it.
87a- OEM power wire.
87 - New 10 AWG wire from battery.
30 - Power wire to the fan.
86 - Ground.
85 - Switch.
Oh, and unlike was mentioned above you will need a 40A fuse. A 20A will pop in time. I was using 20A's until I could get my hands on some 40A ones, and kept popping them. You might want to order those too. They're kind of hard to find unless you have a Car Audio shop locally. Also if you're lucky enough to have a Grangers Supply retail store locally. Thats where I get my crimp shrink termanals, but Del City prices are a little better.
PS I'm working on a timer circuit that will run the fan for a while after you shut the key off to help with the heat soak problem on our later model XJ's.
EDIT: If you drill a hole to run the switch wire into the cabin don't forget to use a grommit on it so the wire dosn't chafe, and short out.
