Yucca-Man
NAXJA Member # 683
- Castle Rock, CO
Same-same...replacing the oil pump pickup is really what everyone is referring to, as the oil pump itself is much more involved to replace.
When I replaced my oil pump, I cleaned and re-used the old pickup tube and screen. When I inserted the old tube into the new oil pump, it was a good, tight fit. But just to be sure, I took a hammer and a punch and "peened" the oil pump around the tube inserted into it. That tightens the fit even further to make sure it won't come out.DBenz said:Along with the oil pump, I've heard there's a pick up screen/filter that needs to be cleaned, is this correct?
Johnny V said:Could the oil sweat be from above and not the rear main seal?
"Above" meaning oil coming from the valve cover or oil filter area.
Is it leaking on the ground?
My Jeep has been leaking for years...it's a hassle now as I can't park it in the new paved driveway and will have to fix it soon.
GI-John said:While you have the oil pan off, and the pump removed, consider replacing the Oil Pump. It's cheap insurance.
Go to the stealership and get the one piece oil pan gasket. You will be glad you did.
John
