5-90
- Hammerspace
AboveNBeyond said:So if I have the one above, one line should go to the deal on the drivers fenderwell, where should the other go? Manifold vacuum or Airbox lid?
There should only be one line going to the EGR valve from the solenoid on the fender liner. That's it. The other line leading into the solenoid should come from the intake "tree" - that funky junction at the front corner of the intake, as I recall.
The lines on the airbox - one should go to the intake "tree" as well (either the plastic junction or the metal fitting with all the branches,) and the other should run along the airbox, going forward to the vacuum actuator (gold-ish coloured thingy on the snout.) Neither of those should go to the EGR.
Are you able to find the VECI label on your firewall (should be in front of the driver's seat underhood,) or has it been removed? That should have a vacuum diagram on it, and it's the best authority for figuring out vacuum on your vehicle. Failing that, someone can probably take a picture of one for you, and send it your way (I don't have one handy - my 1990 in the garage is covered with stuff, and my 88 is in storage. Damned City nitwits...)
