EGR Delete? 90 4.0L
BigDirtyCrew
Brighton Co.
After looking and reading very little about the EGR system on my 90 i get the bright idea to basically try an egr delete and see how it runs. I had the manifold off to replace the cracked exhaust manifold with a pacesetter 2.5" header so this was a perfect time to plug the hole in the bottom of the air manifold and pull the EGR valve off and build a block off plate. Got the plate built and bolted in place and wired up the O2 sensor. I also disconected the EGR solenoid and plugged the connections on the manifold where the vacume hose connected. So i thought i had everything covered but when i fired it up she is running ruff at idle and she smoothes out a little with throttle. Guess i should have asked u guys first but is this even possible and will the engine run a little better without all the emissions crap. Help me out here guys...
My questions are more about how the MAP sensor and the O2 sensor work in conjunction with each other and the ecm. And how come the idle is ruff and with throttle she settles out.
If you have no emissions in CO or it's a trail only rig, do it. It keeps the combustion chamber and intake cleaner. Other than that, I don't really see any benefits. I'm surprised it hasn't thrown a CEL code at you.
No CEL on a 90.
I know for a fact that deleting the EGR does not affect the idle on a RENIX. A EGR that is stuck open will cause a rough idle.
You have other issues or your block off plate is not sealing. I would keep the EGR unless its a "off-road only" Jeep.
The emissions "crap" isn't all that bad on a Renix.
Leave it and make sure there are no vacuum leaks.
Renix, by nature, has grounding problems with their fuel injection system.
Try this first:
Renix Ground Refreshing
The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, and wasted money replacing unnecessary components.
The components grounding at the dipstick tube stud are:
Distributor Sync Sensor, TCU main ground, TCU "Shift Point Logic", Ignition control Module, Injectors, ECU main ground which other engine sensors ground through, Oxygen sensor, Knock Sensor, Cruise Control, and Transmission Sync signal. All extremely important stuff.
The factory was aware of the issues with this ground point and addressed it by suggesting the following:
Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Must be clean, shiny and free of any oil, grease, or paint.
Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Reinstall all the wires to the stud and tighten the nut down securely.
While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, and reattach securely.
Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for it’s intended use and subject to corrosion and poor connections at each end.
First off, remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Reattach securely.
Remove the other end of the cable from the rear of the head using a 3’4" socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely.
A suggestion regarding the braided cable:
I prefer to add a #4 Gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18" long with a 3/8" lug on each end works great and you can get one at any parts store already made up. Napa has them as part number 781116.
A further improvement to the grounding system can be made using a #4 cable, about 10" long with 3/8" terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. Napa part number 781115.
For those of us with Comanches, it’s very important to remove the driver’s side taillamp assembly to access the ground for the fuel pump. Remove the screw holding the black ground wire. Scrape the paint from the body and corrosion from the wire terminal. Reattach securely.
If you want to upgrade your grounds and battery cables in general, contact Jon at
www.kelleyswip.com. He makes an incredible cable upgrade for a very reasonable price.
Revised 12-04-2012
Thanks for the suggestions guys. This is a trail rig only. I dont see why anybody would want this "crap" on their motor seeing what the inside of my intake manifold looked like! U are dumping unburnt exhaust fuel/gas mixture back to clean intake air. I do agree with the grounding issues and will start looking that direction.The block off plate is secure with no leaks so where else could I start looking?
Fuel injector O rings. Any of the hard plastic vac lines may be cracked. The line to the MAP is the most important and the one to the FPR would be next after that. I eliminated most of the hard lines on my 90
