DenLip
- Southwest PA
krakhedd said:Ok sorry, just finally got a chance to check the responses.
Ok. I have '01 4.0 AW4. DIY K&N, DIY IAT relocate to intake tube, Poweraid TBS (yes it does help), Borla cat-back, hollowed primary cat, 180F thermostat, [...] Bad bearings in the front; they make a lot of noise, but I can't see them affecting mileage that much.
The bearings are probably a contributor. The 180F thermostat could be a contributor (making it run in "cold start" mode all the time). I'm stunned that a hollowed-out cat isn't affecting an '01. I wouldn't think the computer would approve of those sorts of shenanigans. (I don't!)
Aggressive tires will certainly hurt mileage. My old Stratus used to get 33mpg highway on it's good tires (Michelin MXV4 Energy), but about 30 on the snows.
All of the intake/exhaust mods you've done CAN, in theory, help gas mileage by making the engine breathe freer. By contrast, if you ARE a leadfoot, they WILL make the mileage go DOWN. The added power has to come from somewhere.
My stock '00 got about 19-20 mpg around town on the stock 225 Wrangler RT/S tires (nickname: slick!)... it's down to a pretty steady 18 with the 235 Pirelli Scorpion AT's.
Den
