Dual batteries are good for winching or any short heavy draw on the system.
An upgrade to the ALT MAY be need also but generally not necessary for this type of load. A fast idle mod has been gone over few time and can be helpful for shorting battery(s) recovery time.
For a on going drain that is even near or above the out put of the ALT. An upgrade to the ALT is called for. Dual batteries MAY help if the draw isn't for two long at a time. But (IMO) the ALT upgrade is the big fix for this type of load problem. The fast idle mod may help here if the load only exceeds the ALT output at idle and the fast idle will not create an unsafe condition.
