XJedi23
- Westminster, Co.
Cant find procedure for measuring front pinion angle.
oo7ravisXJ said:Just finished installing my drop brackets today. Done... YES!!!
RCP Phx said:But a trackbar suspesion needs 3 dimensional movement.The Tera arms are some of the worst out there,they run an extremely hard urethane thats been know to rip the mounts off!Currie "nailed" it as far as "no-binding" goes followed by RE.The JKS arms are quality but still dont really address the issues.
XJedi23 said:Cant find procedure for measuring front pinion angle.
offroader461 said:I have been running these arms on my MJ for about 3yrs. now and havent had one problem...actually plan on keeping them for when i install my DB in the next month or so
Harvo said:Here is a suggestion... When you get them all bolted up and installed, tack weld the braces to the unibody toward where they mount under the T-Case mount / skidplate. If you ever have to remove the skidplate or T-Case in the future, those braces will kick inward about 2 inches. They are almost impossible to get realigned with the holes. I had to use hydraulics to spread them and it was still a PITA. A tack weld will hold the alignment of the holes.
Trust me... even if you have to pay someone to do the tack weld... it's worth it!
XJedi23 said:Gojeep mentioned taping a hole for a bolt. Same results I would think. I will probably weld though. Thanks!
