kmanxj5050
- Reed City Michigan
my drivers side door is sagging already so i am thinking of when i do this. Instead of using bolts making some studs on the lathe to be EXACT.
What about the dome light, just unplug the switch too?
You can also just unplug it under the trim piece, that's always been easier in my experience.yeah you gotta use a socket and unscrew it then just unplug
OP: anyway we could get these pics reworked so they appear again?!?!!
-thanks
Brian
would love to know where to find some door bushings!!!
^^^ What thread?
:confused1:viking:They are a bronze bushing by McMaster Carr (P/N 6338K453) that is 5/16" ID and 7/16" ID so that a 5/16" hinge pin fits PERFECT. They are on the body hinge when you remove the doors. The seats are stock Agate cloth seats from a 2000 Classic.
Material
Bronze
Bronze Type
SAE 841 Bronze
Type
Flanged Sleeve Bearings
For Shaft Diameter
5/16"
Shaft Diameter Tolerance
+0.0010" to +0.0020"
Outside Diameter
7/16"
Outside Diameter Tolerance
+0.0020" to +0.0030"
Flange Outside Diameter
9/16"
Flange Thickness
1/16"
Length
3/8"
Length Tolerance
±0.005"
Load (P Max)
2,000
Speed (V Max)
1,200
Load at Speed (PV Max)
50,000
Temperature Range
+10° to +220° F
Specifications Met
Not Rated
