I retrofitted the vents from an earlier one onto my 95. It's not difficult to do, though somewhat time consuming. If you're not familiar with the way these things go together, the vent window comes complete with its outer frame and the forward window track. If you're seeking out a used one from a junkyard, make sure the rubber gasket has not been distorted too much by years of bad closure, and especially make sure that the bottom pivot, which is spring-loaded, has not rusted, seized or broken. If the pivot gets too stiff, it loosens at the glass frame. It will still open and shut but won't stay open.
