ROKRWLR
- Arvada, CO
I am getting ready to order new longer 7100s for the rear.
Previously I was running 10" 7100s in the stock position with 180/75 valving. In the new setup, I will be running 14" 7100s set vertically over the spring perches. I'm trying to decide if I should stick with the valving I used previously or switch to a higher valving based on some of the recommendations I am seeing on here???
Helpful info:
Should I stick with the 180/75 rear valving or step up to a stiffer 275/78 with the new round of shocks? I am assuming that by going vertical with he shock vs the stock angled mounting and shifting them out further toward the wheels will effectively stiffen the shocks a little bit.
Thanks for the input.
Helpful info:
- The Jeep is chopped and dove'd, but with the cage (typical hybrid exo/internal) added back on, I don't know what the weight difference will end up being in the rear. It has a 35" spare mounted over the cargo area only sticking out past the shackle hangers by 6" or less.
- jeep is not done yet so I can't get any actual weights right now.
- 35's on a D60 FF rear with 3.5" RE leafs + 1" shackles and 1" TNT UBEs.
- Front is a long arm 3 link with 12" 275/78 valved 7100s.
- Mostly crawling, I do like to have a little fast fun between trails, but this is not a Jeepspeed build.
- XJ is "street legal" and driven sometimes, but definitely not a daily driver and will be trailered for long distances not driven so road manners are not a high priority.
