What is the best DIY bedliner? I am looking at doing the whole inside of the XJ. I know there are some good ones out there, but I know there are some others that are just glorified spray paint that flake off after a week.
I used Herc on my old Isuzu truck bed, and will be doing it in the MJ trailer bed soon. It holds up prettywell, and I didn't notice the fading that duplicolor has -- prep is the key though -- scuff the crap out of your old paint!!
i used the duplicolor spray on crap on my rocker panels and fender flares. chipped in one spot but looking good so far after a few months of winter. just kinda faded a bit.
I'm just about to start this project as well on my doors, flares, and kick panels. I have been scrapping that damn 3M tape forever it seems. I have it all gone and have done some light sanding as well. I'm curious to know about thoughts on putting it on the stock fender flares. I'm pretty much ready to go and thinking about doing it this weekend. I wanted to do duplicolor so I can spray it on as well as roll it on.
I really wan to get this right the first time. I've read several posts.
by the way with a properly prepared surface you can use the $69 drywall texture gun from depot and your compressor with the duplicolor bedliner and it will look like a pro did it, medium sized tip and a decent flow of air. no rolling involved, two coats will get it done, thin the bedliner with a bit of tolulene first and mix it well.
The fumes go away after a while, but as soon as the floor board or tranny tunnel would get hot it would be near unbearable in the jeep without all the windows down. As well it seems to retain moisture and dirt better than well...anything else I've come across.
it works great on your stock fender flares. just give them a good sand and do really lite coats. make your final coat the heaviest. i did mine a while back and they are still looking fantastic.
