JP_in_STL
NAXJA Member #767
- Stanton, MO
I'm planning a non-Jeep project that needs a 2 spd gearbox and I was considering using a transfer case to do it. I'm aware of a Suzuki Samurai Transfer Case being divorced and some of the '70s full size trucks from Chevy and Ford having divorced cases. The Sami case will be heavy duty enough for what I need it for and has flanges on the inputs/outputs which makes it easy to mate up to it. Basically I'm making a 4wd gocart.
What other similarly sized transfer cases are out there? Are there other transfer cases that are easily adapted to a divorced configuration by changing a couple of seals and capable of flanges or yokes on the input?
Thanks,
- JP
Thanks,
- JP
