Distributor insight please
WillCherokee
Tacoma, WA
So I have a 91 XJ 4.0 with original engine numbers being 53008405. That engine was messed up so I received another engine that I seen run (like a champ) the the same engine number but it was from a Jeep Grand Cherokee (GC). The difference of the engines I realized was the distributors. The engine from the GC had a Camshaft Position Sensor (CPS) "plate" or "distributor pickup" as some people call it. My original engine had the distributor without the CPS "plate". Where I'm lost is im not sure if the GC engine will run with my XJ distributor. Can someone clear it up for me and the differences between the two. Thanks alot
I have seen two styles. Both have pickups. One is a plastic plate, and the other is down inside. As far as I know they are interchangeable.
I would post this and your other motor questions in OEM Tech. In fact, maybe a moderator can move them for greater exposure.
