Hi !
I have Jeep Cherokee 1989 - 4.0 l limited.
I replaced Distributor Ignition Pickup, but I took it from Jeep Cherokee 1992 4.0 l limited.
Thats true that the wire connector is different but I guessed that the sensor is the same ( I mean electrical specs) , but now after instalation I am not sure.
In my manual there is writen that between blue and gray wire (when ignition is ON) I should have aprox 5.0 V.
When I connect Distributor Ignition Pickup from Jeep 1992 I have only aprox 2 V.
Could you conform that the sensors are different or my problem is not in sensor.
Thanks
PAwel
Thanks
PAwel
