Ok so school me on drivetrains.
Open differentials allow slip left and right. One wheels spins on the axle. during cornering the left and right wheels can spin at different speeds. Right?
Solid, live, locked, posi, Limited-Slip, are all terms for an axle that cannot allow slip while cornering and accelerating. So both wheels on the axle spin all the time...right?
Open diffs save tires and are safer for people on the street. Open diff 4x4s will only give traction to 2 wheels while slipping, one on each axle.
Locked diffs bind the inside tire during cornering and wear tires faster. Locked diffs won't slip off road giving traction to both wheels on that axle. So all four wheels can get traction.
The NP231 transfer case is solid locked gear to gear without slipping FRONT TO REAR. This means nothing side to side...right?
The NP242 transfer case has a "open differential?, clutch pack?" that allows slipping front to rear. This still means nothing as far as slipping side to side...
Correct? Am I reading this right?
Where can I find a list of differentials and what cars they came on, disc brakes, and gear ratio?
