No, the loss is anything but negligible. The 4.0 as used in the XJ in 2000 & 2001 was putting out 195bhp; the CRD's 165bhp is 18% less than the 4.0. Make no mistake: that that loss will be noticeable and the torque gain will only go so far to mask it.
Have you ever driven a KJ CRD? Mine SPANKS THE PISS out of my XJ. Everytime I get back into the XJ I go, "man this thing sure is slow". The power may be lower, but you would never know it driving the CRD, the CRD just about never downshifts while driving in the hills, and will cruise up I70 in the colorado rockies at basically a high idle doing 75-80mph, my XJ struggles to go up the same passes at 60mph.
My CRD KJ has 245/75/16 tires with 3.73's.
My XJ has 245/70/16 tires with 3.55's.
XJ <> TJ/YJ/CJ
4bt is very tall. The couple that I have seen in XJs required 8+" of lift for the pan to clear the front housing.
The KJ CRD motor is also very tall! Requires shoving the motor WAY back against the firewall and pushing the front axle forward some to clear the oil pan. Even then a custom modded oil pan would be preferable.
For the record the same oil pan problems arise when trying to use a US CRD engine in a new JK.
Just for fun I looked on Car-part.com to see what these engines are going for. For the OP, the nearest one is in NC and is $3100 )plus trans, computer...). They are going for as much as $7500 on the site.
Not looking economically viable.
I got my complete rolled CRD limited for my XJ swap for less than 4 grand, I sold off a butt-ton of stuff and now I'm at the figure of less than 3K for the parts vehicle right now.
this parts CRD sold for $850 in denver yesterday:
http://auc2.traauctions.com/kws/napplications/display_pics.aspx?Stockid=977238&Exit=Close
as a chrysler tech is see the 2.8s every now and again. imho i hate them. they are peppy but not power houses either and they are oil leaking piles! they like to leak oil through the turbo and into the intercooler where they eventually blow out the intercooler hoses. trust me its not uncommon to see these libertys with 60k and an engine coated in oil. they still run good but they are more complicated than a cummins 6.7! honestly i wouldnt swap one in anything and am happy they never put them in the wranglers.
The CCV coats the inside of the turbo hoses with oil, causes them to soften, and blow, very common and a poor design from the factory. Jeep now has a newer redsigned hose that has a fluro liner for the passenger side hose. Several years ago I worked with Samco to develope a superior aftermarket hose that would not fail, I still have the original prototype hoses on my KJ and they are doing quite well after 70k miles.
Adding a proper CCV system like a provent or EHM will clean up those issue, you should see how clean my intake is after running like that for the past 70k.
Additionally the EGR puts out so much soot into the system(in an attempt to fight the big bad boogyman NOx) that disabling the EGR by unplugging the MAF is a REALLY good idea. Doing this keeps the intake path clean and the MAP sensor clean as well, I have come across WAY too many CRD's that have been serviced by inept dealer techs who diagnosed blown turbos simply because the MAP sensor was so dirty the Jeep didn't know what to boost too!
My mom has the CRD its a pretty good engine, the only trouble i've had is the damn EGR. Keeps getting sticky im assuming so I just unpluged the MAF sensor that controls is and it runs better then when the EGR is working. That and oil in all the intercooler hoses but thats the damn crankcase breather. on lostjeeps they got alot of info on the CRD engine
yup, lost is a great place, say hi next time your on, I go by SirSam over there.
That sounds like a stupid idea...
Yes it is, but works to reduce NOx emissions. I could go on a long diatribe about emissions controls and compromising all sorts of other things, but as a calibration engineer it works to get it to pass emissions)
You can make the 2.8 CRD work with a manual trans, but its a little bit of trouble, I would recommend sticking in the complete 2.8, 545RFE, and NP242(or 231 if you want they interchange easy).
The wiring is not THAT bad once you get it sorted out, but I spent many an hour working through it all, but basically you strip down the KJ harness to the main connector plugs, interface them to the XJ harness, and then tie into the PCI bus for all your other stuff.
Mine has been an ongoing project, its been put on hold for about 1.5 years now while I finished school and am flipping jeeps untill I find a job(can't afford to work on the MJ, need to work on vehicles I can sell to make a profit).
And I know you've already seen it, but for the record here is my Mj build thread:
http://www.naxja.org/forum/showthread.php?t=955062&highlight=project+crd+mj+born
