IdahoEagle said:If the joint is on the tight side on one side, it can be a binding influence. it has a slight angle to it at all times. If it has too much tension on one side, it can cause it to oscillate when it is put just a little more off center when it hits a bump.
well my issues with DW were on axle joints that were OEM and in good condition and well broken in 80thousand miles,
and as i mentioned before since adjusting to the 1/4" toe-in setting i've not had any death wobble & i've seriously tried to make it DW to test it,
oh and with the same axle U-joints also..
