Joe, could you email an image of that if you still have it? My email is mikeb3485 at gmail dot com.
I have a '92 4.0 auto. 246,xxx miles. It's a Limited model so it has all the bells and whistles. A few weeks ago, I replaced the water pump and t-stat. While I was at it, I replaced the resistor pack because my blower motor was squealing like a stuck pig and only worked on the 4th setting. When I replaced the resistor pack it worked for a second and then blew. So that's when I replaced the motor and a second resistor pack and it was all good. I had some discussion on one of the threads about that with some of you. I pulled the lower trim cover off the dash and replaced some courtesy light bulbs that had blown and I tucked some wires from my CB that have been hanging low for a few years. I also pulled the panel out of the dash that has the temperature slider and heat/ac, etc. slider because I replace a bulb in there too. All was good.
A couple days later, I drove to the Jeep junkyard to pick up a front sway bar. I pulled mine years ago and now that I have a baby I want to put one back up front at least. They wanted too much for it so I said no thanks and left. Only the Jeep was dead. They sold me new (junkyard) starter (for what I was expecting to spend on the sway bar) and it fired up and I drove home. A couple days later, it was dead again. I tried testing the starter and I wasn't so sure of my findings so I took it to NAPA to get tested. They guy there fumbled with it and told me it was bad. He didn't look like he knew what hew was doing but I had a 30 day warranty so I went back to the junkyard. They gave me another starter and I took it home and put it in. Again it fired right up. then the next day the Jeep was dead again. I tried the wiggle of the shift lever that I read about and that doesn't work. Also, it won't start in P or N. I think that means my NSS is good but I'm not quite sure.
I also had my battery tested at NAPA and they said it was good. I also checked it with my own meter and it looks good. I already cleaned my battery cables as was suggested in another thread and checked all of my grounds and they all seem to be good. The battery is a few months old and I replaced the battery cable ends a couple years ago. I suspect that I screwed something up under the dash that day because that's the only thing that's really changed. I also suspect the guy at NAPA didn't know what he was doing and I probably replaced a good starter. What do you guys think?
