Ok gentalmen, heres the story. Drove to a preschool to buy some crack in my 94 4.0 AW4 power everything. As usual she started and ran fine. After being refused procurement of said item for lack of enough Pokaman chips I jumped back in my jeep to search ellswhere. No sparky:bawl:cranks like a bad dog but no fire. Started with the obvious, checked CPS (crank) checked out fine. After a twelve pack and hot lap sestion in the wifes suzuki baleno I moved on to the coil. Pulled the coil to dist wire and held it to my wifes toungue while cranking, no screams or spark:tear: After hopping on old Glue stick our nieghbores shetland pony and hurdaling the burning baleno several times I began testing the coil conecter. Put test light on green side of conecter turned key to on and watched for momentary lighting, that was fine. Moved test light conecter to power side of bat and had my two year old crank it over while cheaking black side of conecter, no flashing of test light as I understand it is suposed to. Quistion, where too from here? By the way I live in Norway= no help here:flamemadlease help, thanks in advance.
