small pederson said:
the dana 35 has problems with the shaft snapping and leaving while still attatched to the wheel. not a very good axle relatively speaking. the chrycho 8.25 with the 27 spline shafts isnt much better. the chrycho 8.25 with 29 splines are stronger than both of those. those came in later cherokees
The early D35's used retainer plates and pressed-on bearings, which doesn't make this a problem. The later ones used C-clips - which is where the problem begins (C-clip shafts are retained at the inside end, inboard of the side gears. Retainer plates press against a press-fit bearing, just inboard of the wheel. If you snap a shaft in the middle, the C-clip shaft will leave while the retainer plate shaft will stay put. Both are, technically, "semi-floating" axles.)
Many of the ChryCo axles are C-clip style, but you should be able to get C-clip eliminator kits for them. You are also limited in gear ratio (what's the cut-off, something like 4.55?) which may or may not be a factor for you.
Also note that there are two spline counts, with a division around 1997 or so. The earlier shafts use 27 splines, which makes them marginally weaker than the later 29-spline shafts (assuming the same pitch, a shaft with a higher spline count will be larger - therefore stronger. Assuming the same shaft diameter, the higher spline count splits the driving force out over a larger area - therefore making it more durable, all else being equal.)
The ChryCo axle started showing up on the XJ and MJ in the 1991 model year. If you
do have ABS, you have a D35 - if you do
not have ABS, it could go either way, with the odds favouring the ChryCo. The C8.25 was not issued with ABS (not that I'm fond of ABS anyhow.)
