RWKHausSupply
- yorba linda, Cali
Dana 44 high pinion center in great condition from a Ford 3/4t pickup
Tubes pulled.
New HD tubes installed with XJ/TJ inner knuckles.
New Currie HD bracket kit with upper Johnny Joints by currie installed.
New Electric locker (with switch and harness still in bag).
New Currie chromoly 4340 inner axles and ujoints.
New 1310 ubolt style yoke
New HD dana steel cover
New true Spicer ball joints
New inner seals
This thing is stout and the High Pinion so better in many ways to any waggy or other D44 swap. Not to mention uses your XJ rims.
No gears in it right now. 2150$
I will get a premium set of new gears and master install kit and set it up ready to go, 2410$
This assembly is stock XJ/TJ width and wheel bolt pattern, takes your outer knuckles, hubs, brakes, and outer stub axle. Swaps right over. direct bolt in strength and ready to rock. Can do a complete ready to bolt in. I will accomidate within reason, to unload this.
Robert
7one4-875-24one4
Tubes pulled.
New inner seals
Robert
7one4-875-24one4
