Just would like some opinions on the first contact pattern i have taken. The stats are.. 1987 cherokee xj dana 44. Everything is new except outer pinion set up bearing. The pinion depth is at .0425" the back lash is around .008-.009". ALSO when i took apart the axle there is was no stepped baffle under iner bearing race. should i use the one that came in the rebuild kit or not? i have read you dont need to on the rears just the fronts. Any info would be great. Thank you.
[URL=http://s1312.photobucket.com/user/AJs01XJ/media/D44008-009bl0425pd_zps524ca446.jpg.html]
[/URL]
