Mutant_Xj
- Susquehanna Valley
I'm thinking of swapping my D30 in my 93 sport for my brothers D30 from a 97 grand laredo. My jeep is making a weird vibe during a slow turn and sometimes feels like its binding some. I figure swapping the axles would be an upgrade for the U-joints and maybe his wont be in as bad of shape.
Questions
-Are the unit bearings and the breaks the same. If I could unbolt my caliper and put it on the new axle I wouldn't have to bleed the brakes and could save myself some time.
-Am I missing anything. I have been told the Zj axle will fit in the Xj. I'm assuming I'll just have to unbolt the control arms, Drive shaft, shocks, and calipers. Swap axles and bolt everything back up.
-Would it be easier to swap just the shafts? Do you have to change the axle seal when you change the shafts? If I have to pull the carrier do you have to mark the R&P so the same teeth match back up? I haven't heard if you do, and if you do how? Are the unit bearings the same? I don't have a 36mm socket right now and it would be quicker to swap bearing with the shafts anyways.
-I was leaning towards swapping axles because I didn't know if the ball joints could be bad, how do you check for certain? I had the wheels jacked up and was tugging and twisting on them and they felt solid and I watched the knuckles as I jacked them up and the wheel didn't drop at all and I couldn't lift up on it on the jack stands.
Thanks for any help. I did search but didn't find enough info to make me comfortable enough to just start tearing into my DD. If there is info on this that I missed please point me towards it. I've read Go jeep's and MadXj's write up on changing axle shafts and seals, and doing ball joints. I have yet to do anything like that, and don't have much cash to get new hubs and ball joints so I'm trying to use what I got.
Questions
