RWKHausSupply
- yorba linda, Cali
I would not verify .006-.010 backlash, and alot more load to the carrier or pinion as you try to take a pattern, its hard to tell with what you have there. Maybe ok, but hard to tell. One thing that works for most people, is a drill with a 3/8 to 1/2" adapter in it, then put your pinion socket on that and use the drill to turn the pinion, while you put a hammer handle or prybar against the ring gear end wedged against the housing to create drag.
