DANA 30 CHROMOLY 4340 AXLE KIT COMPLETE - $369 TILL END OF JULY!
RWKHausSupply
$369 till end of July
Yep, its time again. Get your High Strength 4340 Chromoly Dana 30 axle kit for less than any store else has offered in Years, including myself!
This is a Complete Axle kit that also includes The axle seals and disconnect block off kit. NOT JUST AXLES. You also get the strongest OE style Ujoints for them, the Spicer Forged 5-760X ujoints.
You Get:
4340 (2)Inner & (2)Outer Shafts with a no questions asked 1 Year warranty on them.
(2)Spicer 5-760X Forged Ujoints
Central Axle Disconnect block off plate kit with Both side axle seals for the conversion.
These are on sale for basically $75 off (20%) till the end of July. AND you can add a spartan locker to the order for only $255, thats a Huge discount!
http://www.rwkhaussupply.com/magent...r-tj-xj-yj-wj-zj-front-dana-30-27-spline.html
As always, these ship from multiple locations across the USA and most orders only take 1-2 days after payment to get to your door.
Ask around and you will find, RWK Haus Supply is your Best option when it comes to Drivetrain Part Selection, Price and speed of delivery.
Robert
[email protected]
If I told you who "Made" them you would be lost. Cause only kits over about 800$ are made by the company named on the box. These are made in India typically. And reboxed. Typically these are the same exact imported shafts from same company as most everyone else in the sup 800$ rebox also (Brand N, Brand Y, Brand T, etc)...
Yes they will fit a full clip, but dont come with them. They can be added for 20$.
Any chance of shipping to Canada?
in a 4340 shaft, not much, maybe a bit. In a mild steel shaft, the ujoint ears are weak, and under high stress/loads the ujoint can stretch the opening for the ujoint cap and the cap may spin. If it does, typ the C clip cant spin with it (no clearance for clip all the way around the ear) or doesnt want to. And the clip gets spit out. Then cap falls out and bad things happen.
With a aftermarket shaft and full clip, they cant get spit out and they help integrity slightly.
All ordered and I guess they have already shipped. Thanks again
Yes sir, your order from friday shipped friday and will be at your door today. A tracking # was emailed out friday. Let me know if you didnt get it and need it again.
Thank you.
Got it. Processed and will go out today. Out of Fresno CA (Closest warehouse to CO) will likely be 3 days though. CO and NM are the longest sates to get to.
Thank you for the order.
only a few more days till the extended to end of August, is over...
