Dana 30 Carrier Question
bmsmalley
Montgomery Texas
I have a HP D30 with 3.55 gears and am going to run 33 x 12.5 x 15.
My questions:
  • Do I have to switch the carrier to run 3.73 or 4.10?
  • If I buy a locker for my current carrier with 3.55 gear will it work in a carrier for 3.73/4.10 should that carrier be a different than 3.55
Changes are coming and in the plans, I just need to plan accordingly, thanks in advance for your input.
You will have to change the carrier to run 3:73 or higher gears. I would recommend going with a full case locker such as a detroit or grizzly because of known weakness of the stock carrier. If you get a lunchbox locker for the 30 it will work in either carrier.
