Blondejon:
All the components in the d30 are in good working order, so its not some random serviceable part causing this .
As to how it reacts on pavement:
the symptoms are immediate and compound the longer it is driven. I remember when it first happened it rolled forward until my steering pretty much became unresponsive, and had an "oh sheet" moment thinking i had somehow grenades my front end.
Offroad:
symptoms are substantially less as far as the passenger side pull is concerned. but the driver's side pull when in reverse is strong enough that if i don't hold the wheel is jeep will make a wide circle.
I know everyone is thinking locker, but it was working just fine before the swap, and it behaves identically to my buddies locker when we compare engagement and disengagement of my locker to his, while our front ends are on stands.
I don't have a lot of time to mess with this right now. So i figure i am just going todo what i had planned on doing prior to this bs: install my drop pitman arm, do an alignment, and go wheeling.
After finals i guess I'll pull the mini spool in the 9inch, drop something else in, and swap spiders back in the front.
