flyingbrick
- Monterey CA, San Luis Obispo
so i'm having a small leak on the driver's side tube on my rear xj-d44, leaks down the tire overnight, i keep tabs on the diff fluid constantly and it never seems to drop much, so i was told on this forum that the rear only had an outer seal on the axle shaft, then i went to the parts house they told me there is an inner and outer seal, can someone explain exactly where those go? and is it possible i switched the shafts and put the longer one where the shorter one goes? i have an odd vibe that i can't seem to get out. specs- 90xj, 3.5-4" home brew lift, 33x12.5x15 xterrains on 3.5" backspaced steelies, 87 xj d44, jb conversions sye,
thanks for the help!
Joe
Joe
