yossarian19
- Grass Valley, CA
Stop before you see brake fluid, that's for sure.
I'm pretty sure you have to change the bore on the ID as well as the bp on the end of the axle tube(w/ the ZJ setup) but I believe the explorer setup is a bit easier to adapt to the 44. There are plenty of threads on here check them out..
I'd move that pan-hard bar up to the top notch on the axle side.. you want the Pan-hard/Drag-link to run as parallel to each other as possible
looking at pictures, i think the JKS bracket that your axles have only has 2 holes, correct? i think the angle the pic is taken at may also make the angles look much more different than they are.
take one from strait on.
I need to drive my jeep Thursday. If I can't get my rear brakes working can I just cap them and use only the fronts? They're WJ brakes. I think it'll work until I can figure it out.
Kingkong0192, do you have any bends in your tie-rod to clear the dif cover? It looks straight to me.. does it clear dif cover ok?
Oh, wait ... you're doing this on the D44? or an 8.25? My bad if it's the D44 as the pattern is completely different and yeah I guess you're drilling anyway. Then there's the axle retainer issue to deal with./QUOTE]
Yes. D44. I'm damn near positive i have to redrill the bolt pattern on the backing plate. It isn't even close to a 1/16" off. More like 3/8" or so.
Axle retainer issue it already dealt with. I just need to drill out my backing plates and put them on the axles and slide the axle shafts in.
Here are some pictures of the rear. Should be finished tomorrow.
