Quacked
- New London, MN
I just finished replacing parts in my D30 dif due to blowing the spiders which of course had to knock a big hole in the ring and pinion.
I found a "low milage" used front for $150. I bought the assembly with the intent on trussing the housing, adding jonny joint brackets and welding on the new brackets for a ROR Hi-Steer kit, then getting the housing completely tore down, sandblasted and powder coated before I put the much needed 4.55's in it. I was going to do my spare 35 the same way at the same time.
Well the low milage front upon tear down had a fair gear set and spiders, but the bearings were way brindled, almost blue. So I had to spend more money, and order a superior overhaul kit.
When I bought this XJ, it had 100,000 miles on it, but had been ditched hard enough to tear off the exhaust. The truck has always had a vibration in the front (almost a harmonic) that would start shaking the keys at 65 mph. This was before it was lifted, and still my wifes driver. In trying to defeat the vibe I had rims checked for straightness, tires repeatedly balanced, and the front shaft out several times to check for straightness and balance. Nothing fixed it. So I started to speculate that maybe it was play in one of the pinion bearings or maybe output shaft bearing in the xfercase?
So I was excited to see if the vibe was gone.
Unfortuneatly, it seems worse, and now my keys are shaking at 50 with my well balanced BFG all terrains and new winter wheels.
Front shaft removed, and there is no vibe.
So it was obviously not the pinion bearings, so I am going to hypothesize what it may be and see if anyone agrees.
What are the chances the vibration are from a slightly bent housing and is being caused by the axles moving in the dif. carrier off plane?
The only other cause I can think of would be the output shaft support bearings.
What else do you guys think it could be?
Now here is my other question.
I was suprised by how tiny the axles and ring gear were on the D30, and am starting to question spending any money on the D30/35.
My truck with 33's does spend most of its time on road, and pulling a big duck boat tandem axle 20 footer, and a 16 foot fishing boat is required.
I want to have extreme reliabilty, but dont need to ge real big like 60's. If I truss the 30/35's, will I just keep breaking dif's?
I am loathe to go to 44's because I have a sweet set of wheels, but will have to if I must.
SO if you were needing to use your truck like I do would you do the 30/35 with superior super kits, or go with stock 44,s from a full size Cherokee?
Thanks,
Brad
Thanks,
Brad
