330LICIOUS
- NorCal
I've got a couple of D30's and other stuff I need to get rid of so I can make room in the garage and yard.
Dana 30 Low Pinion, open, with 4.56 gears (professionally installed at Rearend Specialties in SJ). The axle came out of my 2000 XJ and has about 65,000 miles on it. The 4.56 gears were installed at around 45,000 miles so they're only about 20,000 miles old. I can check receipt of install to get the exact number. Comes knuckle to knuckle, including brake calipers but no pads/rotors... $230
Dana 30 High Pinion, open, with 3.55 stock gearing. I purchased this off of CL a while back but went with another option. These were the numbers that the original owner gave me when I bought it from him: 1998 XJ, 80,000 miles. Comes knuckle to knuckle, no brakes... $110
Teraflex Adjustable Trackbar used for one year on my 2000 XJ. The benifit of this particular trackbar is that you do not have to disconnect either end in order to adjust it... $120
http://www.teraflex.biz/products/front-adjustable-trackbar.html
Rubicon Express RE1600 used, from the same HPD30 that is posted above... $100
http://www.rubiconexpress.com/SuspensionSystems/Product.aspx?part=RE1600
Rear Hitch 2" Class III, pulled off ever since I got my rear bumper, earlier this year... $40
Also have stock steering: draglink, tie rod, trackbar. Make offer.
Thanks.
Thanks.
