WB9YZU
- Madison, WI
D30, Low Pinion, 4.56 Gears.
When I had the Jeep torn down to find the source of a Clicking noise, I found a chipped tooth on the ring gear. Since it was large enough to have a part number on it I proceded to tear it down. When I pulled the carrier, the bearing shells fell off, which I expected.
What happened next took me by suprise, I grabbed a bearing race to hold the carrier and it slid off the carrier. I did the other one, same thing. There isn't slop there, I'm just able to do a shim adjustment without setup bearings :gag:
I'm looking for a temporary solution until I can upgrade from a LP to something else. Since that involves more money, that may not happen for a few K miles.
My 1st impression was once the correct shims were located, to loctite the bearing on to prevent spinning.
Other ideas?
Ron
Other ideas?
Ron
