IDK, looking for a JY white hood to recut tighter around the SC and don't have to paint or just paint this one. Probably going to leave the SC open uncovered, it really attracts attention. Leaving the rear hood lift, 1.2", as that really helps with under hood cooling.
Super easy install in an afternoon. The SS box is now all plug and play, it comes with a connector/jumper harness all wired together which plugs into the ECU and tune loaded. 6-6.5pounds boost, AFR 11.5-11.9 under boost (safe but a little rich) IAT's 160-180 at WOT. Spent more time going slow in this 100* heat and rounding up bits and pieces. Kit $1000, SC $100, SS controller $580. I added a 62mm TB and CAI mod with 3" hole out the bottom of the airbox and hosed to a duct behind the fog light opening.
Autocrossing- this thing is a beast. Lowered, wide tires and rims, HD front sway bay, shocks, sub-2900pounds and this handles like it is on rails. No body roll. Flat, responsive, controlled. Went to one local SCCA event and was turned away at tech b/c it is a 'high CG roll over potential'. Sent in a letter of petition to SCCA. They allow a GMC Typhoon to run. Collecting a file to present to them. BMWCCA? seems a bit more open. The Turbo XJ-R just ran with them and placed 10th out of 100, not too shabby, and surely annoyed some BMW drivers.
