I have a Currie CE-9710 Heavy Duty Tie Rod System that is used for almost 2 years. It has tabs welded to the tie rod for the hydro-assist (easy to cut off)
The TIE ROD has a bend in it. Nothing major, it should be easy to fix due to it being chro-mo. You will also need new TRE boots & zerks as well.
Ill take $170.00 for it. Pick-up in Simi Valley or i will ship/package on your dime!
