tigerchief
- here
Hey all,
Need some info I couldn't find after some searches.
Quick run down:
'99 AW4 4.0l NP231
--> need to remove the two studs for the cross member. One is sheared. One of the other nuts is stripped and turns inside frame rail (bolt is used here).
Question: are these nutserts? Can I just tap them out, and replace with new nutserts or are they welded nuts?
Only thread I could find was this: http://www.naxja.org/forum/showpost.php?p=243527078&postcount=20
Thanks in advance.
Quick run down:
'99 AW4 4.0l NP231
Thanks in advance.
