yea well just cuz u have a 23 spline t case doesn't mean they are all the same! went to put in the t case yesterday and the hole was different on the t case so the tranny saft didn't fit in it! GAY!! HECKA GAY!! so anyone have a 231 plantary gears out of a 91 and up auto! i need them
Yea more info is needed. I have two 231's in peices in the shop that I am trying to combine into one and a crawl box. Both have 23 spline inputs and are the same. How deep is the input on your 231? Just measured both of mine and they are a little under 2".
well we counted the splines on both the tcase and tranny and then we measured the inside diameter of the t case and the diameter of the tranny output shaft and there were different sizes??
Why is it you guys are having so many 231 problems? First Billy-the-kid, and now you? Everyone else on that planet can mix and match 231 parts with no issues.......
I don't get it. A 23 spline male output will fit a 23 spline female input. There are no differences in spline contour or size. Hell, my Dodge NV 4500 23 spline output slid right into a 23 spline 231 input.
man thanks for double checking me, I'm getting old and the memory doesn't work much after being in and out of atleast a 100 or so t-cases in my life. :angel:
Ok next question. Wasn't there a diference in planaterys at some time or another? And did it affect the input at all? Have you guys priced the input gears? WOW! My input is out of a 92 or 93 231. Will it work in his without any problems?
there was a change made to the tooth pitch profile. I found this out trying to use an 86 t-case with 95 internals(planetary) I installed the 95 planetary assy. in the pressed-in 86 orbital gear, and the damn thing sounded like a huey....
I have not determined when the change was made, I am guessing that the difference was made between amc-series to j-series, and I also think, although I have no real info to support this, but I think there is actually three tooth varieties to date
