CobraMarty
- PM me any questions
As part of the Sprintex S/C install I put on Ceramic coated Gibson headers, wrapped them for the first 4-6 inches or so and then stuck 'gold' heat barrier on the underside of the supercharger manifold. What I did notice was about 5-10 degree cooler water temps. Before it was just over 210* and now it is under 210*. I will look closer and check it with the OBD scan gauge. The S/C manifold is shorter runner and not as big and heavy, maybe less heat soak. I will also check some IAT readings.
