8Mud
- Central Germany
Spanky414 said:Is this spring loose? Can I transfer it from the one on there now to the new hose or is it built in?
If you can find one with the spring already in there buy it. Taking the old spring out (it´s rusted and will snap off, or catch and stretch) is a pain. Getting the new or used spring in there is even a bigger pain. Noticed the guys at the Jeep dealership, cut the spring in three pieces, then stick the pieces in there.
If you have the standard clamp type hose clamp, toss it and buy a screw type, heavy duty if you have a choice. But don´t overtighten or it can cut your new hose.
When I get a hose joint, that doesn´t seem to want to seal with a little tightening, I clean up the water pump inlet with a 3M pad, clean the inside of the radiator pipe with a rag and some hot water and put a very thin coat of RTV on the inlet. Isn´t really any harder to take off, than a radiator hose thats been on there for awhile. Silicon rarley sticks to the hose and comes off the inlet pretty easy. A small tool of some type that will fit between the hose and the inlet pipe (to gently pry them apart), is often more productive than brut force. I heated and bent a thin screwdriver 90 deg. about an 1-1 1/4" from the end, use it for various things, including getting between stubborn hoses and the pipes. I rounded the sharp edges just a bit, works well.
