I have drained my radiator by the drain valve. Is there a drain valve in the engine block? I could not find one. It is an 89 XJ 4.0.
The coolant were brown and i flushed the system and filled up with radiator cleaner, and did a second flush. Why does the coolant get so full of rust?
I replaced my cooland bottle last year. Now it is totally brown inside, and it looks like it is developing cracks. Looks like it blows up from high pressure inside. Should I have replaced the rubber band that hold it?
regards
Torfinn
regards
Torfinn
