- Terra Firma
I posted in your parallel thread on OEM that I don't like Dr. Dyno's method of tricking the ECM. On the '99 the same temp sensor serves the aux fan and the injection/ignition. Data goes into the ECM and the ECM controls the fan. Dr. Dyno's XJ, based on comments in other threads, is not U.S. spec and thus what worked for him may not work on a U.S. spec vehicle, especially not a '99 with OBD-II.
Okay -- here's a simple solution. The old Renix non-HOs ('87 - '90) used a simple switch in the radiator tank to control the fan. How about taking your radiator to a shop and have them solder in a threaded bung to accept one of those switches? Wire from that switch to a relay for each fan and you're done. I believe the temp setting for that switch is 217 degrees, although my '88 FSM says 190.
