luvherinmyjeep32
- Pennsyltucky
i have an 89 XJ and i converted to the 91+ open style cooling system. i bought a 91 XJ heater valve from adv. auto and im n about the 5th one now, because they keep leaking coolant out of the small hole in the side where the metal arm from the vac. diaphram enters the plastic piece to control the valve, only when vacuum is applied though. at first i had it plumbed incorrectly but now im pretty sure i have it right...
left side goes to heater core and you can see the orientation of those hoses on the core at the far left in the picture. top right goes to the t-stat housing and the bottem right goes to the waterpump. is this correct?
any thoughts on why these things keeps going bad? are the ones from adv. auto junk? does the valve need to be mounted in a different position maybe?
