cruiser54
- Prescott, Az
Those of us who have eliminated the heater control valve. I'm assuming since it always runs through the heatercore, that we are going to experience decreased mileage?
No. Why would we?
If he isn't getting heat and the temp is staying around 150 when running, the issue is in the cooling system. The Oxygen sensor is not and cannot keep the engine temp at 150. Even with a failed Oxygen sensor, my rig had no issues staying hot. Bad fuel mileage and idled poorly yes, but the heat was fine.
Fix the cooling system issue first.
I agree to fix the cooling system first.
But, I think you're misunderstanding Ecomike. He's saying it is going into closed loop even at 150* but that the oxygen sensor is the cause of the poor mileage.
I'm not sure I agree. The only way I'll find out is to hook up my DRB-II and monitor the system from start up and see what temp it goes into closed loop at.
I'm not so sure that the thermostat is that bad. I think that running the heater at full blast when it is below zero provides enough cooling to keep the temps down, even if the thermostat is pretty much closed. You would be surprised how much heat a heater core can dissapate.
The next time you are on the trail and you are overheating, turn on the heater full blast and watch the temp drop like a rock.
I'll stand by my decades of cold weather experience with this setup and others. If the engine is running freeway speeds (think I noted a reported speed of 85 mph), it will generate plenty of heat even with the heater running full blast to keep the engine coolant temp at 190ish, regardless of whether it is operating in open or closed loop, provided the thermostat is operating correctly.
Had a thought. Why doesn't EVERYONE, especially those with bad oxygen sensors, who lives in a cold climate have this over-cooling issue in their XJs? I don't and I see 0 to teens all through the winter. Have a good oxygen sensor now but didn't last winter.
I just had 2 Stant super-stats go bad on me in the same Jeep. You must be truly blessed and/or haven't replaced one in many years. I replaced the second one with a factory stat that has the "jiggle valve" and now the heater is satisfactory. I tested the hoses with my laser temp sensor before and after BTW to verify.
Too lean and the difference between a working and non-working oxygen sensor are 2 different things. A working oxygen sensor does not make a Jeep run overly lean, nor does a non-working oxygen sensor make it run so rich that it runs cool.
Kinda figured the diesel question would be raised. Yes, you do still see some diesels using winter fronts in cold climates, such as where I live. And yes, they do serve a purpose. Diesels, from a heat generation perspective, are more efficient at using their heat as part of the power producing process. They can also generate a ton of heat when working hard. As a result, many diesel systems are on the overcooled side of things. In addition, depending on the application, diesels typically will generate very little heat at idle, so the winter fronts help with that situation as well.
I think we can all agree the Cherokee is on the undersized side of things in the cooling realm. Of the gas vehicles I've driven, the XJ has never been accused of poor heating.
As far as bad thermostats, I've never seen so many bad ones as in recent years. For whatever reason, it seems like the ones the Jeeps take are particularly prone to it. My previous replacement took three thermostats to get one that worked right (two cheap parts store branded ones then a $15 dollar one from the dealer solved it).
