Vanimal
- escondido, ca
i have 16" coilovers in the rear running a triple rate setup with 300lb 16" lower springs and 150lb 14" upper springs giving me 5" of lift. this is a 100lb primary rate.
now i'm tryng to find a suitable spring for the front. i was looking at the rusty 4.5" springs which have a 150lb spring rate. how much heavier should i go in the front vs rear? is 150lbs going to be too soft?
specs are 91 4 door 4.0 a15 manual doors and windows, 40lb front bumper, 3/16" frame stiffners, and about 40lb rock rails, and long arms. no cage yet, no rack. i was also looking at the RE springs but those are 240lbs/in but that's a huge difference. anything out there thats a happy medium?
i temporarily have pro comp 3" springs and 2" spacers in the front and it seems like its a little stiff compared to the rear as the rear flexes out long before the front.
