- In the islands
Since pushing down on the trottle body tend to reduce the RPM's, I would concentrate on the trottle body.
Disconnect the trottle cable, TV cable and cruise control cable. Maybe one of them is sticking.
Check the TPS to see if that is holding the trottle open.
If that do not solve the problem, lube the trottle body shaft inside the throat as well as outside while opening and closing the trottle engine off course.
Lastly, there is an allen screw under the plate that is used to adjust the closing of the trottle plate. The trottle body have to be removed to access the screw. I have never heard of anyone who had to adjust this.
On my XJ, the butterfly closes completely. There is no light visible between the plate and the body. It seem something is holding the one on your XJ open.
