Is anyone running the Clayton offroad 3 way adjustable shackles ? Did you have an problems with them ? Are there any issues with running up to a 2.5" extended shackle ?
I do not have them, but depending on leafs you have and yoru shackle angle, lift shackles can cause some axle wrap. Check d-line angles, shim if necessary.
well i got rustys offroad 3.5" leafs with a teraflex 1.5" shackle but the springs are junk and have sagged so i am thinking of swapping out the shackles for the claytons that way i can adjust them as i need. . Thanks for the replies.
