AwesomeXJ
- Vancouver WA.
the only other issue I see with the 3link system is the upper arm runs between the front drive shaft and floorboard. I already knew i needed to modify the tunnel for top clearance. but won't my down travel be compromised by the drive shafts close relation to the upper arm? I want super flex. but the way it looks is if i run my passenger side tire up really high it will cause the upper arm to travel down and make contact with my front drive shaft.
EDIT: Nevermind I was looking at the pic wrong. ya that looks like a better system as far as it not binding or unloading but still looks like it is limited in the total drop distance. though not needing limiting straps is good.
