I pulled the pan to change the oil pump, rms, and have a look around.
After priming the pump (coil disconnected), I no longer get spark. It's not flooded and has been down for a week.
I did accidentally move the oil pump drive a bit when installing the pump.
Troubleshooting:
- Checked Grounds
- Checked fuses
- Checked cps connector (have not multi metered it)
- set TDS and restabbed distro
- no spark at coil or plugs
If the CPS and cam sensor are off, I believe fuel would be taken away not spark. Am I wrong?
Suggestions?
Troubleshooting:
- Checked Grounds
- Checked fuses
Suggestions?
