Ben824
- Woodstock, GA
Ok so my 97 XJ leaks really bad in the rain and the driver side foot well fills with water so I got out the hose and started running it over that side of the Jeep and it leaked from the huge wire grommet that is under there so I fixed that. There was a leak coming from a grommet that was a up and over towards the driver side some more and I fixed that. And the grommet for the driver door wires leaked bad and I got that under control. Problem is there is still a leak that I cannot find where it is coming from. I can tell that all that I fixed helped because the carpet was soaked but I did not have a puddle of standing water an inch or two deep like I did before. I did find that it only leaked when I ran the water through the vent for the cowl so I removed the vent cover and stuck the hose in there and it got even worse to I pin pointed it to something in there but I cannot see down in there to find a crack or anything that could be leaking.
The water runs down from where the red circle it but I cannot see up there to find what is leaking.
Does anyone know what above that area could be leaking? I do not have a garage to keep this thing in and I am tired of finding water in my Jeep.
