As long as the electrical plugs are the same, and the ends physically fit and seal, you should be fine.
Yes, the HO injectors are a bit higher-rated for flow (about 10%, as mentioned,) and your fuel economy may suffer a bit, but the HEGO feedback loop should help trim that down. An adjustable supply for your MAP sensor may help with the rest - but that should only be tuned when you can read the exhaust yourself (using a wideband HEGO air/fuel monitor. You can "guesstimate" it - but it's easy to run it lean instead - and that can cause more damage than running rich.)
